Another helix question
J
jds
I'm running an 09 m8 Boondocker at 12lbs. Have been running a 36/46 and it works well this will be the first trip running 12lbs last year was 8lbs. Came across a secondary that has a 46/36 helix in it. Was wondering I anyone has tried this set up. Also I am running cat weights not real sure what weight I will be running going to start with 80gram I also have 82gram and 77,78 grams. I will be in the snowies. Riding between 8-11000ft
Thanks guys
I guess my question would be is that 46 going to up shift to fast and not let your motor build rpm/ power before the turbo comes in.
That's what I'm worried about. Not much of a clutching guy. Worse case I try it and it don't work. It's all set up so it only takes 2 min to swap clutches out
