After 15+ years of being used as a "access" road and camping spots, is it really considered "fill" anymore? I mean, its not like we just dumped a few truck loads of dirt down and started to build on it.
Thanks for all the replys and input guys.
Right now concrete is running $90-100 a cubic yard. I live in Deadwood, SD. The lot is reletively flat, other than the walk out side tapers off. There is absolutely no bedrock as the lot was primarily fill dirt 15+ years ago, so there will be no blasting. As far as I know SD doesn't require framing, insulation, drywall, ect... You can just have the concrete walls. There will be two egress (sp?) windows in the bedrooms, so that will add some.
As I said, only digging in about 5 feet tops, the rest will need to be filled to bring the elevation up for positive drainage. If there is any hauling it will be bringing dirt in. And they won't have to go more than a half mile for that.
RMK900Rider, maybe I should hire you as your price sounds great and is similar to what I want to do! Haha.
Obviously the Steamboat prices aren't really relevant as that is a whole other issue as far as property value, building, etc.
I know I don't have any idea what is going into actually getting a basement where it needs to be, but $60,000 of the overall $190,000 cost seemed a little steep to me for a pretty basic design house. Were talking 4 corners with a walkout and two windows.
I agree, seems a little high for the basement you are doing. Your concrete prices seem about the same as here in NW Minnesota. I will be watching this thread, as I am in the beginning stages of building, and should be getting a bid back next week on framing and the basement. My project is approx. 1700 sq feet on the main floor with a full basement underneath. I too will have a few windows and a walkout basement, as we are building on a slope. I am planning on doing alot of the interior work myself minus the sheetrock (I hate doing that). Good luck with your project, I will let you know what my bids come back at.
Here are my figures from 2005 when the materials price was extremely high. The cost of materials is much lower now.
I built a modified 2 story, 9 ft cielings, stone, large windows, etc, I will try to attach a pic
Basement - 1200 sq ft, 9 ft cielings walk out with a daylight view on back. Garage is 35 x 28 Cost was 22k for the foundation and flat work
HVAC - I did my self with a heat pump and all york equip 12k
Electrical - 250 amp service I did myself 7k
Structure - framing cost 22k
Materials 80k
cabinets/tops 17k
plumbing 13k
septic 10k
drywall- hang/ tape/ mud/ prime 10k
I did all trim work, stone, tile, electrical, hvac, dirt work, siding, installed windows and doors, deck, etc
I built this house which is 2400 fin sq ft and 1200 unfinished, 3 bed, 2 full bath, 1 half bath, and unfinished basement on 3 acers for 215k
SD,
I live about 65 miles south of minneapolis, 30 miles north of Mankato.
Took me 9 months to build this house, but it wa sall worth it when the bank said I have 250k in equity.
That is the plan,,,,,,expcept more land which i intend to buy within 2 years
Looking to be on ag property so the land makes some money for me by renting it out. Probably 40 acers
next house will be a single level with a walk out basement, 4000 sq ft with radiant in floor heat, furnace connected to geo thermal heat source and LP back up with a electric plenum heater on off peak.
I have to stay within a coop electric provider, off peak rates are awsome. Currently at 60.00 per month to heat my house with my heat pump,,,,above 20 degrees
Next house will also have cement board siding, heck of a lot better than vinyl!!!!!!! I will NEVER do vinyl again.
The one contractor I've got a bid from so far said he would sign a contract to not go over budget, so that is good. We'll see what others say.
when you build your house, price the primed cement board against a premium vinyl,
