09 M8, stock primary and secondary springs, 42/36 helix. Last year I rode for a 1000 miles with no problem, lots of hard riding and never letting up on the throttle, sled ran great. I did blow one belt on a long hard pull, and I will say that was my fault. I was running for 20+ minutes, in really deep snow, very hard. This summer I took the sled to a dealer to gear to 54/66, since I got it back I installed the SLP pipekit. Sled runs strong with the pipekit, but I blow belts very quickly with WOT. Sled is well ventilated. I have blown four belts in 100 miles. Today I installed a 120/340 primary spring, running 73 gram weights between 0-4000 ft. Sled runs REALLY good, not overreving. Pulls real strong. The belts will go quick in the deep snow WOT, but seem to do OK elsewhere, and the pulls are nothing that the sled didn't handle the year before.
I plan on checking alignment. Should I have the 2010 front motor mount installed? Could this be a problem if the gearing was installed incorrectly, like higher gears installed instead of what was asked for? There was a mix-up at the dealer with the gearing and I assumed they got it right, but when I got the sled back it didn't feel snappy, like when you gear down, and I get some fast ground speed out of it when I am on hardpack. In the back of my mind I am thinking that the top end speed just seems too fast. I had a 46/38-34 helix and after gearing the sled just didn't want to pull RPM's anymore, so I went with the 42/36, and seems to be a lot better.
I will check gears, then align, then motor mounts if suggested
