HI
NEW TO THIS FORUM, USUALLY ON AMSNOW.
ANYWAY, HAVE AN 05 FUSION REBUILT LAST FALL AND RAN ALL WINTER. NO MAJOR ISSUES UNTIL THE LAST RIDE. STARTED RUNNING FINE , THEN I NOTICED A "LITTLE" LOSS OF POWER, THEN MORE AND MORE AND MORE TILL IF WAS LIKE RUNNING ON ONE CYLINDER. MAG PLUG WAS DRY, PTO WAS WET, CHANGED PLUGS STILL RAN AWEFUL. THEN CHANGED THE FUEL FILTER-OLD ONE DEFINITELY CLOGGED-A LOT HARDER TO BLOW THRU THAN THE NEW ONE I PUT ON. MAYBE IT HELPED A LITTLE, BUT STILL RUNNIN BAD. COULD A CLOGGED FILTER HURT THE FUEL PUMP? IF SO HOW CAN ONE TEST IT? IS IT POSSIBLE SOME FILTER MATERIAL HAS CLOGGED THE INJECTORS?? COMPRESSION IS GOOD AND PISTONS AND CYLINDERS LOOK GOOD-I DONT KNOW WHERE TO START?
THANKS
PHIL
THANKS
PHIL
