Has anyone ever had any parts anodized? Im not look for function moreso looks. If you have had this done what type of coating did you get, hard coat or soft coat? Also where did you get it done?
Did another race boat in black hardcoat, polished as well...don't have any pics tho, it comes out like a transparent blackish real dark grey as opposed to the vivid black of the color anodizing...remember though it will add .002-.003 thousand to everything and your not going to run a drillbit throught a hole if its to tight...so get the thickness from the shop first then open your dimentions up then send it off.
If you're going to anodize parts on a sled, it should be done in a Type 3 hardcoat only. Anything else and you run too much risk of it flaking away. IMO anyway...
I had the suspension rails and my HRP gas rack hardcoated on my Assault. You will have to remove the track adjustment brackets on the rails as noted and clean up those areas as you do not want ANY steel remnants in/on your rails. I also wet sanded and polished my parts before they shipped out. The better the prep work (polishing), the better your parts will come out.
I had mine done by Anodizing and Metal Coatings out of SLC, Utah.
One of the great things about anodizing is that there is little to no surface build up, so there is no problems come reassembly.
Yeah sometimes its good to have the .001-.003 as it tightens up the factory slop..lol
oh fyi color anodizing is a dye that impregnates the metal, it cant flake off like powder coat or paint. But will fade in the sun over time and will scratch ect as its soft.
You are right...I should have worded my statement better. What I was getting at is that you can scratch through the anodized finish to expose the bare metal, and decorative (colored) ano is more susceptible to this, thus Type 3 Hardcoat should be used for better durability (tougher finish). Decorative ano is also more susceptible to fading as you noted.oh fyi color anodizing is a dye that impregnates the metal, it cant flake off like powder coat or paint. But will fade in the sun over time and will scratch ect as its soft.
Anodizing is the way to go IMO, presuming you're after black rails. A Type 3 hardcoat is a tougher finish and is easier to reassemble due to the minimal surface build up. You also eliminate the risk of weakening the temper in the aluminum during the baking process that is used for powder coat. It seems that as long as they're baked at a low temp for a short duration you will be fine...but if you can remove that variable all together...why wouldn't you? That's my take on it anyway...Thanks for the Good info here. I really want to coat my rails this summer .trying to decided between powder coating or anodizes.!
