Date of Failure -
found problem 4/21/2012
Year -
2010
Make -
Polaris
Model -
Dragon
Mileage -
950
Engine Displacement -
800
Track Length -
163
Brand of fuel and octane -
91 non ethanol
Oil Used -
Polaris VES gold plus
Mapping -
stock
Ethanol Resistor connected -
unplugged
Elevation that you ride -
6-12000
Area's or locations that you ride -
Snowies in WY, Island Park, ID
Modifications, Turbo's, Pipes, Cans, Brands -
stock
Fuel Controller's -
none
Intake Modifications -
none
Clutch Mod's, kit -
60g weights
Gearing, if other than stock -
stock
Fuel filter Replacement, when and at what mileage -
installing now 950 miles
Engine mods, t-stat mods, porting, etc. -
none
Aftermarket Boards... -
betterboards
Drop N Roll -
no
Any prior service or warranty work performed at the dealer -
voltage reg, oil pump (sticking)
Warranty yes or no -
no
When did Warranty Expire -
January 2012
Updated Pistons yes or no -
pulled apart to install fix and found cracked cyl skirt. .015 of piston to cyl wall clearance
Type of Failure ie Piston, (from lean, deto,oil ) Crank and or Bearing, Rod, etc.
Compression Test/Results if done -
no
Was check Engine Light Blinking Prior to failure -
no
Injector Color
Type of Sled Transportation, Enclosed, Open, Deck, etc. -
Open with covers
Sled Storage, Indoors, Outdoors, Enclosed Trailer, Heated Shop, Unheated, Summertime Storage, etc. -
stored inside garage
Weather Conditions, Air Temp on the date of failure -
unsure when it happened
How may miles into the ride failure occurred - ?
![cyl.png cyl.png](https://www.snowest.com/forum/data/attachments/149/149226-fae72c2157a386967e63673d5e340efd.jpg?hash=-ucsIVejhp)
