Stiff secondary spring and light pin weight = not loading the engine and blown belts. Throw some pin weight in there and shallow up the Shockwave for the hills.....you'll have more belt squeeze on both ends and more consistant RPM under a load. I think you'll find everything is a compromise with the Shockwave...it works "good" but doesn't have the angle spread to work as good as possible in the hills. We need a good clutching thread to make the summer go faster
Is it not that your RPMs would determine your Clutch squeeze, ie to much clutch squeeze lower RPMs and visa versa... so... what is the better setup to run, high helix angle and a higher clicker OR lower helix angle and lower clicker... the lower helix and lower clicker would be tighter belt squeeze all round would it not...??? SO......
one step further what is the down side to "lots" of belt squeeze? i guess the down side to not enough belt squeeze would be the primary slipping over the belt creating heat.
