I believe lots of water, but it is very important to have good cardio health, too. Use the treadmill for a month prior, a couple miles. But I think what also really works the best is this Voldyne can that a doctor requires people to use prior to heart and lung surgery....$20http://www.onlinemedicalsupply.com/RESPIRATORY/RESP_MISC/HUD8884719009/product.aspx?iorb=4764&?utm_source=yoms&utm_medium=yoms&utm_campaign=yoms What this tube/can does is that you suck air from this can through a hose very slowly and for a long time so that a puck is pulled up to a certain volume.....the larger the volume the better, but you must pull air into your lungs slowly in order to build up your lung capacity. The first couple days of use you become very light headed after the first couple tries, but after that you really feel your lungs begin to strengthen and your lung capacity significantly increases...this helps adapt for the smaller amount of air at higher altitudes and prevents your lungs from having to work so hard to breathe.
Sounds like a low altitude to get altitude sickness, you must be very sensitive, small planes are restricted to 10,000' without oxygen, but they can fly at 10,000 all day. So I would assume that means almost everyone is immune at that altitude.
