I do keep them in stock. As for the rod ends im thinking you mean upper a arm to spindle? On that you use your stocker. The lowers use the same stock ball joint. You may be looking at the other arms that use the large rod ends with the misalignment bushings? Sorry I havent put up a pic but if you go to the ski doo cromoly a arm page they look exactly like the 39.5''. Thanks!OT warning. Do you keep the cro mo 37" rev setups in stock? Lead time? Do you need to buy the rod ends or can you use stock? are offset bushings required? Just went to your site and all these thoughts hit me, could use some info. Thx.
