Send them to Gashshockrepair and have them re-valved. They're way better once you get them re done2020 hardcore alpha comes factory With QS3 and qsL coil overs. Been pretty happy with them. Other then the front track spring has to be cranked close to full tension On 2 and 3 setting to stop bottoming out, would like to try a dual rate spring. Fyi I am a fussy suspension person. I ended up running raptors on previous two sleds. And I’ve rode 19 Alphas With the cat air shocks and I think there terrible! Even after playing with all the settings.
That would depend on your budget and what you expect out of the shocks. The Elkas have more adjustability with high/low speed compression and rebound adjustments. The hardcore shocks only have the 3 position wide range compression adjuster. So if you really like to fine tune and adjust the suspension Elka would probably be the way to go. If you're the "IDK I just set it to 2 and ride it" type of rider then the hardcore set is probably good enough.Would it be better to buy a set of Elka‘s and just roll with it or fool around trying to find a set of hardcore take offs and then mess with having them reworked?
Sent you a pm.The hardcore shocks are kinda Spendy from country cat!
