air temp sensor in cold air intake tube or not??
L
lightening800
am just wondering, i rode my sled this weekend and had multiple codes for the intake sensor voltage high and manifold air pressure codes aswell, now could this be caused by the fast moving air by the sensor when its boosting or is this normal. i was told the sensor does not like fast moving air or moisture of any sort, is this true? i can relocate it to the electronic cover but thought it would be a good place for it to see the actual air temp that going in the engine. this is a twisted 800 dragon 2010. thanks
mount it in your cover or somewhere else that will be cool and dry. sounds like you got it mounted in the airflow its not a MAF sensor its just a temp sensor
It's not like that ADA that Boondocker is running in the charge tube so there is no way to adjust fuel as per charge temp I would mount it under the plastic gaurd.
