I got tired of trying to keep the snow out of my airbox so I decided to delete it and try something different. I also have been having some carb icing issues so I installed a KTM carb heater. For the intake I used a 3" chunk of 2.5" silicone hose that just barely slide over a 2"X3" ABS reducer I then used a 3" - 22.5 degree ABS elbow to clear the subframe and then drilled out a 6" long piece of 3" ABS to use for my prefilter cage which I will be running an outwears prefilter over. Installing the carb heater was a lot easier than I thought it was going to be and aside from drilling a hole in the carb and tapping it for the heat probe everything was plug and play.
I haven't taken it out on the snow yet to see how this new setup is going to work but I am headed out Monday and I will report back. My bike is looking pretty bare with the radiator shrouds being the only plastic left on the bike but I am thinking this new intake should give me a lot less problems.
