Did you check the relay above the secondary clutch. I have a 2005 summit rev 800, and when I got it out last year, absolutly no lights came on. It ended up that the relay that I am talking about was bad. My local Napa had a replacement in stock for around $10.00. Anyway, the relay is zip tied to the aluminum frame. Other than that, I am pretty sure that the LED lights do not require as much power as the traditional lights do so you may need a voltage regulator of some type or something. I am interested in relocating my tail light too so it will be interesting to see what the fix is. Where did you get your light from? i was told that the 2003 2004 short track MXZ's had the lights in the seat from the factory, so i might try to locate one.
