So in all fairness we need to compare apples to apples. My kit is complete with all hardware, no pressing bushings in or out of your stock arms. Our 36 inch kit is adjustable from 36 inch to 37 inch still being able to be centered on the spindles. This year we have the option of a heavy duty lower arm or the normal strength. What that amounts to is we bumped the lower arm rear main tube( using the new Docol )by one tube size. Not something your going to wipe the bulkhead out with. Rod end design gives you a shear point so on an impact "possibly" replacing a $18.50 part instead of an a arm.Rod ends on both upper and lower arms means a fair range of camber adjustment. Replacement lowers $185 (stock depending on location $230ish). Uppers $95. All moly kits have sway bar attachment. Our axys kits come with all new hardware. Zbroz you need to press out bushings from your stock arms and back in. Zbroz have arched lowers. Unless they changed something recently on the 36" kit you cannot use the sway bar. Kmod I believe come with all hardware and sway bar tabs but no sheer point, no Docol material and about $150 more than ours. The skinz are a forward kit that could be a bonus with the pro but IMO unnecessary on an axys. Correct me on what I'm inaccurate with I'm going off memory. Price on the skinz was $1299.00 But comes with spindles and arched lowers.No clue what indivual replacement cost is on other brands. As you can see not a bash session, everyone just really needs all the real world info in front of them to make the purchase that best fits their needs. I'm sure I barely touched on everything but I think hit on the important ones. Thank you
Dan
