OFT Racing's Moto-R Kill w/ Jacobson Roll-over Valve *NYTRO*
http://oftracing.com/OnlineStore/index.php?main_page=product_info&cPath=58&products_id=101
larger image
$179.95
Fits: 2008-2012 Nytro
Tired of your engine oil recycling itself through the airbox and out the tailpipe? Rolling any dry sump 4 stroke Yamaha generally yields that result...
[FONT=arial,helvetica,sans-serif]The patent pending Jacobson roll-over oil valve kit is designed to prevent engine oil loss during a roll over event of Yamaha 4 stroke snowmobiles, and has now been integrated into OFT Racing's "Moto-R Kill" tether system. [/FONT]
[FONT=arial,helvetica,sans-serif]The OFT Racing “Moto-r Kill w/ Jacobson Roll-over valve" (patent pending) will take care of this problem, while also providing you with a top of the line engine kill tether system. In addition, our kit plugs directly into the factory wiring harness with no slicing and dicing of your OEM wiring harness!![/FONT]
We have designed this kit using OEM Yamaha weatherproof connections and a completely sealed Bosch style relay and connector. Installation of the OFT Moto-R Kill w/ Jake Valve is nothing short of idiot proof! Unplug the OEM harness, plug in the OFT Moto-R Kill harness, and install the Jake valve in-line on the oil tank vent. If for some reason you need to remove or bypass the tether kit, changing the sled back to stock form is as easy as unplugging one or two connectors and plugging them back in to the OEM harness. The Jake valve will remain in a "flow through" open position.
Designed to compete with, and surpass more expensive competitors products, The Moto-r Kill w/ Jake Valve kit features the race-ready and off-road proven tee handled Pro Armor kill switch assembly. The Pro Armor switch provides extremely easy "gloves on" operation, and bullet proof, all weather performance. With Pro Armor’s positive clip latching, you never need to worry about a cheap “rubber plug” not seating or trying to thread a needle sized clip through a pinhole with your thick gloves on as with our competitors.
The tether switch will mount on either 7/8", or 1-1/8" handle bars, and the kit includes a "test plug" that will allow you to disable the red OEM handlebar mounted kill switch.
