I've never really understood the point of "wet weight." For comparisons with sleds all that tells me is sometimes sled makers have different fluid capacities. Fluid is a constant and to me even figuring out the best MPG sled tells me you can loose some weight by putting less fuel in! I'm also afraid sled makers start making sleds with lower fluid capacities just so they can quote a lighter wet weight. 5 less lbs of gas is almost 40 lbs less weight!
The most interesting number to me is after riding weight to see how much snow and ice the sled likes to bring with it. I realize it's pretty subjective as it will vary with conditions, type of snow, riding, and just dumb luck. I know a long time ago yamaha viper did an after riding weight to show the viper wasn't as heavy as it seemed because it carried the least amount of snow. Artic cat did something similar with the pro climb as well. I hear the most complaints about polaris carrying the most amount of snow with them. Raw aluminum tunnel, coil spring shocks, larger tunnel cooler, design of the skid, running boards, all seem to play into how much snow it brings with it. I'd love to see arctic cat do an after ride test with the alpha one to show if it really sheds snow as well as they say it does.
