After Market A-Arms
good call heres the titanium set
I was going to get the Alt impact Ti a arms but I have had bad luck breaking Ti a arms on my nytro in the past. Titanium is nice and light but likes to break instead of bend. Just my experience. I broke 2 sets of Diamond S Ti a arms with very little impact. Although it may be just because of the weight of the nytro.
With respect to others building Ti parts, not all are going to perform the same. Yes Ti can be on the brittle side depending on grade. Without giving too much away here certain grades can be used on different applications. There are to my knowledge over 100 different grades. They don't always break without bending. Here is a pic of one on my personal sled that I hit a stump with. Beings its the front tube I never bothered changing it. Heres a tip that "REALLY" needs to be passed along whether its Ti or cromoly.. Carry 4 small (good grade) stainless steel hose clamps at all times. If you take out an arm you can splint the bend or break with the clamps and a wrench or even the screw driver tip that's in the tool kit. In some situations you can take both lower main tubes out, in which case one lower arm may be the least of your problems, but none the less it really works pretty good. Thanks! Dan
I picked up a set of the Z-Bros arms for my old 2011 Assault. Installed them when i needed them and found you had to grind out the back end of the spindles to get turning radius. Not a big fan of this so probably try Alt Impact this go around.
Well you have to cut some other parts if you go with the Alt Impact arms;)
Have both and really like them, top products and top support from Dan (Alt Impact) and Nathan (ZBroz)
