Is there any setup out there that has any sort of longevity to it?
I'm kind of tired burning my knuckles trying to take plug readings on my M sled
I would like to have something that just tells me where I'm at, but nearly everyone I've talked to says AFR gages are lucky to read properly past the first ride due to oil being burned in a 2 stroke...
Is there any setup out there, perhaps a heated sensor setup, that will work with any kind of longevity on a 2 stroke sled?
... Two stroke sounds like a tough environment for this to run in.Chris,
What is your confidence level in the partial closed loop mode running the AFR on the Gen 3.5 box. On a TWO Stroke sled. (Bosch controller on a Bosch sensor)
Would this be "rock solid" on a 2 stroke or would the owner have to worry about the system kicking into limp home/default mode??
Lots of the turbo setups run the two big "No No's" of the Bosch lambda sensor.. Oil and .
If you are using Gen 3.5 with an Aftermarket AFR gauge you can just unplug the wire going to controller and it will default to the open loop code. This doesn't require the user to reprogram the controller.
If you are using our Wideband controller you can just unplug the sensor and it will default to an open loop code.
