Kit is in good shape and everything is in working order. Kit is complete but will not come with the dial a jet which is needed for this kit to work correctly. You will also have to supply your own expansion chamber.
1200.00 for everything
Kit includes.
2004 summit 800 carburetors drilled, tapped and fittings installed
2004 non HO 800 head
Turbo
Exhaust pipe ( turbo outlet not from engine to turbo)
AFR Guage with an extra sensor
Boost Guage
Boost reference fuel pressure regulator
Electric fuel pump
Intake piping with plenum
Signal lines from plenum to carbs etc..
Couple feet of fuel line
Extra gaskets and adapter plate to adapt your expansion chamber to the turbo.
Extra Aerocharger oil, enough to do 2 or 3 oil changes
Kit located in BC, Canada. You can text or call Jamie @ 15878970973
Kit includes.
Turbo
Boost Guage
Electric fuel pump
