The Aerocharger Hybrid Snorkel Intake is now available:
By allowing for multiple intake areas, this design improves on traditional snorkel setups by increasing air flow and reducing the risk of blockage.
This kit features a heavy engine compartment shroud, which blocks heated air from the engine and clutch compartments. This shroud is a fiber reinforced high-temp composite and does an excellent job keeping engine and clutch heat from bleeding through. The edges of the shroud contour with the stock panels to form a good seal.
![](http://i1068.photobucket.com/albums/u452/Aerocharger_jerry/Aerocharger%20Cold%20Air%20Intake/th_IntakeInstalled-Inside02_zps025fab66.jpg)
![](http://i1068.photobucket.com/albums/u452/Aerocharger_jerry/Aerocharger%20Cold%20Air%20Intake/th_IntakeInstalled-Inside03_zps1593fe80.jpg)
The Aerocharger can then draw air from both the snorkel filter and vented mounting bracket. The snorkel bracket has been sized to enable a large air volume to flow into the turbo compartment, thereby maintaining efficiency. The surface of the bracket is covered by a SnowSilk vent screen to increase the intake area.
![](http://i1068.photobucket.com/albums/u452/Aerocharger_jerry/Aerocharger%20Cold%20Air%20Intake/th_Bracket-LowerSide_zpsb8aea152.jpg)
The snorkel's filter sock is stretched over a semi-rigid spring for best durability from objects while riding. The flexibility of the spring tends to keep snow from sticking to it, and air will continue to pull from the vertical surface area even when other intake areas are blocked. This should ensure that your Aerocharged sled will always have an unobstructed air source to draw from. Should additional snorkel height be needed, this setup can be easily customized with an extension.
![](http://i1068.photobucket.com/albums/u452/Aerocharger_jerry/Aerocharger%20Cold%20Air%20Intake/th_IntakeFilter_zpsbebcf3fc.jpg)
The Aerocharger Snorkel Hybrid Intake kit retails for $350. We're doing a limited run for this mid-season release; for orders or questions give us a call at 913-829-3400 or email info@aerocharger.com.
![IntakeInstalled-Outside_zpseacc9fd2.jpg](http://i1068.photobucket.com/albums/u452/Aerocharger_jerry/Aerocharger%20Cold%20Air%20Intake/IntakeInstalled-Outside_zpseacc9fd2.jpg)
![IntakeInstalled-Inside01_zps3468321c.jpg](http://i1068.photobucket.com/albums/u452/Aerocharger_jerry/Aerocharger%20Cold%20Air%20Intake/IntakeInstalled-Inside01_zps3468321c.jpg)
