Mine idled fine until I got the 2010 update then it acted funny at idle, seemed to hang up at 1500 for a little bit then drop to 950 or so. I just turned my idle screw up a half turn and now it stays idling at 1700 all the time. Seems to be fine again now.
Once you do that it messes up the T.P.S. setting.
T.P.S. is set w/throttle blades fully closed to a certain voltage.(.70 VOLTS +/- .01 volts)
Then the idle speed screw is opened up until another voltage spec is set.(.94 or .95 volts depending on model)
No further adjustment beyond that.
Check out the info under "INCREASING YOUR IQ" Thread
take it to the dealer and have them check and readjust the TPS its common for them to go out ..mine did!!
