Clutching is like a space ship to me, ill get that out there.
With that, any of you recommend a good adjustable clutch weight set?
Suggest against adjustables?
No need to do anything to the secondary, these weights are designed to work with your stock secondary, that's the beauty of it, I have friends and know of others that changed their secondaries with these weights only to change them back, The stock works perfect with this setup. An average of 6-8 more horsepower to the track, your not making more HP, but you are getting that much more of the HP you have to the track. And yes, they bolt right in, 10 min or less and your done. I do recommend the delrin washers in your secondary, and also the SLP Helix shim, it gives the secondary just the tad bit more backshift that the pro lacks for descents...IMO.Do the MDS wts just bolt right in withOUT having to modify the primary?
If your sled is dialed pretty good with OEM wts, can you leave your secondary alone and just mess with wts and primary spring?
thanks!
