Actuator rod?
up-high
My MCXpress is over boosting. I fixed a bunch of leaks in the system. I think previous owner just tried to increase boost to compensate. No boost controller so I was wondering how to adjust the waste gate actuator rod. Anyone know how many turns per # of boost? I shorten the rod to lower boost right?
Thanks
you want less tension on the rod to lower boost, thus thread it out.. as for turns per #.. not a real exact number. just start looseing a few turns and get it figured out. doesnt take a tone of work.
i see you have a 310 chip using actuator rod to control boost at 17psi your bottom end will suffer it's not noticeable on 8psi but using a boost t or better yet a true boost controller allows you to put back pressure on the wastgate witch makes a big difference on bottom end and spool up time and recovery it was well worth the money. on mine i got full boost 1000rpm sooner.when using one of these your actuator rod is suppose to be a half a hole out from the pine on the tight side.so you are only moving the actuator rod a 1/16 inch or so.
<TABLE border=0 cellSpacing=3 cellPadding=0><TBODY><TR><TD style="FONT-SIZE: xx-small"></TD><TD style="FONT-SIZE: xx-small"></TD></TR><TR><TD vAlign=top></TD><TD></TD></TR><TR><TD vAlign=top></TD><TD></TD></TR><TR><TD vAlign=top></TD><TD></TD></TR><TR><TD vAlign=top></TD><TD></TD></TR><TR><TD vAlign=top></TD><TD></TD></TR><TR><TD vAlign=top></TD><TD></TD></TR><TR><TD vAlign=top></TD><TD></TD></TR></TBODY></TABLE>
http://www.aemelectronics.com/tru-boost-boost-controller-gauge-757
</TD><TD style="FONT-SIZE: xx-small">No external interface required for programming!</TD></TR><TR><TD vAlign=top>
</TD><TD>Complete system includes harness, boost hose, on-board 29 PSIg pressure sensor (external 75 PSIa optional), boost solenoid, gauge display and all necessary fittings</TD></TR><TR><TD vAlign=top>
</TD><TD>Quick connect technology eases the installation process</TD></TR><TR><TD vAlign=top>
</TD><TD>Two user selectable boost settings with peak boost memory</TD></TR><TR><TD vAlign=top>
</TD><TD>Scramble boost setting allows user to momentarily change boost levels</TD></TR><TR><TD vAlign=top>
</TD><TD>User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost</TD></TR><TR><TD vAlign=top>
</TD><TD>User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display</TD></TR><TR><TD vAlign=top>
</TD><TD>One (1) low-side output included for warning lights
keep the solenoid away from heat it will not take it.
There is alot of companys that make manual boost T's. Pretty much any hotrod shop can get them for you or sell them. I have great luck with turbosmart, lots of people use halman. Boost controller should be mounted closest possible to turbo/wastegate. I also sugguest you looking into getting a vacuum pump. That way you can check for leaks, & see what pressure your wastegate opens at. The vacuum pump I have does vacuum & pressure. Its a hand held tool, got if from Napa dealer, $100cdn. I will try to find the part number. It makes turbo troubleshooting life alot easier. I also use the tool @ work in diesel semis.
Got the controller today. The line from the turbo and the line from the wastegate go into a little box(solenoid?). The instructions say to disconnect these lines but leave the wires connected. Is this right? Any pics of where you put the controller would help also. I think I'll mount it just in front of and to the side of the wastegate (bolted to the tunnel). That way, I can adjust boost just by taking the seat off.
