Accessorizing the New 2010 M8 SP
O7\08 gauges
Does anyone make a gauge pod like the amp for the older style speedo gauges, that does the same thing? If so and you have one on put a pic on here and where you got it, thanks
Yes. This is copied from another thread....
AMP-9916 Arctic Cat 2005-2007 MONSTER CAGE
Our newest Gauge Cage, the "MONSTER CAGE" fits the Arctic Cat large speedometers which came on the 2005-2007 M-Sleds.
Like the original, this mount relocates your stock speedo so it can be read while standing up and also acts as a vent to allow heat to escape from the engine compartment.
Comes complete with hardware and instructions.
$129.95(USD) Click picture for larger image
http://www.aftermarketproducts.com/c...hp?mach_type=S
One issue I had with the gauge cage was that the template sent with it from AMP was completely wrong. The holes were not even close and fortunately I double checked before drilling the hood. Glad I did. I would not even bother with it if I did it again.
The best way is to just center up on the hole then rotate the cage until the lower bolt holes are the same distance from the warning sticker that is located under the gauge. For me, it was about 2.125 inches. Get it really close, drill and bolt one side then adjust the other to exactly match.
Placement of the holes is really important because if it is mounted with any skew, it won't look right.
Let's see some more pics of other people's mods on the new M sleds.
Cheers :beer;
