It is stock Polaris. It is made so that the engine has to be running for any DC to flow. I'll be picking up my new one Tuesday. Will post pics.
Okey, you were lucky.. The fuel pump draws to much power, that I have found out.. But, yesterdays testdrive resulted in the sled stopped and I can't get any power out of the stator.. I measured the two yellow cables that comes from the engine and up by the clutch cover, 00 ACV..
Can it be the fuelpump sucking so much power over time that have caused the stator to die? The really funny thing is that when I measure the stator, the OHM value is spot on and it is not short cirquit.. And I didn't meen HA HA funny =/
Stator should produce 14v of power. Can be checked at yellow wire going to capacitor. Out of regulator should be 12v constant. At all dc power outlets 12v as well. For example dc wire under hood most hook 02 sensor power to should b 12v as well, easy to check.
Mine is starting to lose power at anything less than 4500 rpm.
Here's what I've done thus far: replaced bad stator, it helped but not fixed. Swapped capacitor and voltage regulator, still not fixed. Found 02 sensor was sucking to much power so I replaced and it's no longer sucking power but still not fixed. Unplugged a/f gauge it helped but still not fixed. Unplugged all turbo accessories still no fix. Tonight I'm swapping fuel tank and then ecu off my stock pro. 1 at a time to see if one fixes problem. If all that fails then wiring harness it is. Funny thing is I have the Polaris diagnostic computer and it can't tell me what's wrong specifically just that it's low voltage!! So in my case it's process of elimination to find problem and dealer would be no different.
Relay didn't work either, all grounds r good as well. I'll report back tonight if Not to late.
