abs backpack canister weight
P
pura vida
can someone please tell me the weight of a FULL canister. its off an escape 15 if it matters, don't think it does. i weighed mine and it came out to 484 grams, just want to make sure it's full, would kinda suck to find out it wasn't! thanks
pv
PV:
Original full weight should be on the neck of the bottle. If I remember right you want to send it in if it ever gets 10% below the full weight listed. Good luck. EW
is the it punched?should be kind of full then?maybe you have better weight scales than me!
What color is your canister? The weight of the silver canisters is different than the weight of the black canisters. Also, was that the weight of the canister with or without the cap?
it is the black canister and i weighted it without the cap. just took it out of the back and stuck it on the scales. and i tried to find the weight on the canister but it is all in german or swiss or norwegian or whatever it is, i can't read it.
pv
The weight of the black canister, without the cap, should weigh approximately 480grams. If your canister is within +/- 10grams, you should be okay.
