Aaen MXz 670 twin pipes
Set of older painted pipes, some minor dings, some surface rust. Been moving them around on the parts shelves in the shop for too long now, time to go. I do have the set-up sheet for these pipes, and also have the recommended clutch spring to go with them.
These will fit a 670 Summit, IF you use an MXz motor mount plate.
Make me a reasonable offer....
They won't fit a Summit without installing spacers under engine plate mounts, or better yet, installing an MXz mounting plate. These pipes are designed for an MXz, and the MXz engine plate mounts the engine lower and at a different angle. When I had them on my Summit, I went the spacer route, which was a real pain in the rear trying to make everything fit. However, if you wanna go this route, I would take $100 for them....
