OK, need a couple suggestions if you got em'
Species: '08 M1000/ Twisted RG
Symptoms: Soon as it fires up it blows the fuse and I lose instruments & Tail light. Also (don't know is it's associated or not) AEM gauge goes nuts cycling through 111,222,333,444,555,666,777,888,999, and then some random letters before starting all over again.
History: Working fine when it went into the garage for the Twisted set-up. Took off the spedwerx set-up, timbersled intake and boondocker box (along with all associated wiring). Turbo is up and running well but this electrical issue is really slowing me down.
Tested so far:
Gauge and headlight harness - Clear/ when the fuse blows I lose gauge but not headlights (unplugged the entire harness and it still blows)
AEM Gauge - Clear / unplugged, still blows
Tail light harness - Clear
Cold start (interrupt switch) - Haven't completely cleared this one yet, disconnected it and the fuse didn't blow. So thought I had it, started unwrapping wires and getting ready to re-wire it or find the fault. Just for ****s and grins fired it up again and this time it blew the fuse...go figure.
Attitude box - Haven't tested because I can't start it with no power to the box but it seems to be operating properly.
All wires in the twisted harness appear kosher. At his point I have been staring at the same damn wiring for 5 hours and am out of ideas to check. I welcome your suggestions or ideas.
Thanks
Tested so far:
Thanks
