Ok I'm tired but I'll try.
I have been towing with 1/2 ton 04 Titan snowmobiling and summer recreation. I double tow in summer just over 9000' with two dirt bikes in back full up against payload.
Winter I towed a 4 place Wells Cargo. Got rid of the trailer. It was within limits BUT pushed the truck around on snow and ice. Handled it but didn't like it. We have to park on Forrest Roads. 27' trailer heavy tongue weight on dirt snowpacked roads sucked. Got rid of it.
Got Pace 2 place 17'. Still had to use anti sway on non-local trips and weight distributing hitch. Was well under limits but you sure knew it was back there.
I also had a Top Cat when I first bought the truck, piece of cake.
Just bought new truck opted to 3/4 ton. (There Ollie didn't mention what kind so holster that pistolla partner)
Loved the 1/2 ton and esp the Titan. What a hot rod. 100,000 miles in three years. 9500 tow capacity 1650 payload.
Open trailers, no problem at all. Summer pulling, no problem at all.
______
You need:
AT Tires w/ sipes. Great ones, costly ones. I went through 2 sets of Toyo Open Country but didn't change them out in summer. AWESOME tires change everything.
Weight distr hitch. (will keep you from bouncing along, throwing up, and wearing out your springs in a few months)
Antisway bar for longer trips or on high speed open highways.
PROBLEM: You are not supposed to use wd hitch off road. I always did.
Maybe great airbags that won't kill you non-loaded. If you tow close to payload alot springs will sag.
Best deal is if truck has factory towing. Mine was and worked great had all the coolers etc. This area has to be professionally figured out on modern power systems. too much trans coooling = big problem with operating temp. too little + bye bye big bucks.
Excellent trailer brake controller. (If open two place won't need Or Top Cap) Four place and enclosed will require this.
Studded trailer tires are a real help. Not only with additional stopping power, but helps keep the trailer from blowing or sliding sideways.
If you're 1/2 ton is not designed as a tow machine, and you try to make it one, you probably won't really have the capacity to tow heavy.
Forget the BS about towing overloaded blah blah, you get into a big bad accident and everyone will abandon you and that doesn't even count death and destruction. It's illegal to tow over limits or unsafely.
I know some show big trailers etc with dinky SUV's and there are snowmobile areas where I see them. However if you tow other than major highways and have to park on dirt roads covered in deep snow, then get serious about what you do because getting stuck or being unable to stop sucks.
Remember also You're truck is lighter than a 3/4 and if your tow rig is heavy then you have something to watch out for more than a 3/4 ton. The heavier you tow the more the trailer can push you around on snow and ice. Inclines matter. Wind, matters.
just match your trailer weight, tongue weight and have proper set up and you'll be fine. Ignore part of the equation or push one end of it and you are ripe for a wild ride at best.
Good luck.
PM me if I can help I've towed all over the west with weight in the winter (100,000) with 1/2 ton.
Tough decisions I know.
