A little something to get the blood Pumpin'
I'm excited for mine also, wounding what helix and spring combo polaris settled on.
Polaris recently published owner's manuals for the Matryx RMKs, which includes these clutch specs for the 850s:
WeightDrive SpringDriven SpringHelix
N/A Low Elev.10-72150-290 (Almd/Gld)140-200 (Red/Blue)60/44/.36
N/A 10-68120-320 (Black)155-222 (Black)STR 42
Boost14-78165-310 (Almd/Red)160-240 (Blk/Prpl)64/44/.40
Awesome thanks, hope this is not the clutching that was leaving black streaks on the boost demo sleds.
  • Sad
Reactions: TRS
Thats what was in the test sled i rode, peaked behind the clutch and they had spring written on sheaves. Its basically Carls helix and spring they've run for the last 15 years it seems.
Hoping we can build some spacer adapters and get some @TRS weights in there and run his combo. WHile the boosts I rode ran damn good, I've also rode almost that exact clutching combo on turbos in the past and know tonys outruns it and makes less heat.
Our TRS weight will not fit in the P22. There is not enough room for the tip or the tuck. Polaris added a reinforcement rib along with a larger center hub to accommodate the bearing.
I have a P22 that I have been working with. The 10 series style weight has been back cut at the tip to allow it to rest in the P22.
The comparison is the new weight along with a 10 series behind.
553FBC78-DEA4-4AF4-9BAE-E4DFD670F802.jpeg B50663D7-FD55-4D53-A86D-FDEB2B2E6E14.jpeg FF79CD50-68A8-4C88-96EF-92FF0ECE238C.jpeg 4E5F458B-3C0E-43E1-8488-4BB70520A54F.jpeg
What’s your overall impression of the clutch?
Will there be any increased longevity?
  • Wow
Reactions: TRS
What holds the spider on the new clutch, snap ring?
In reality the clutch bolt and the primary spring. There is a Clutch bolt tower that is removable. It incorporates a shim/spacer that holds the spider in place. The one I have has a measurable gap, this leads me to believe the spider will migrate. That in turn would allow a belt to sheave gap to fluctuate. I’m going to see if that can be rectified.
The spider and stationary are splined. It takes very little heat to remove the spider.
