a little silber help
G
Gone Sleddin
2012 silber kit on a 2012 pro.
headed west this weekend so i wanted to make sure it was still running. took it out here in MN and when I try to run it wide open something is going on... when i punch it to wide open the box flashes the red lights and the blue indicating boost. it then goes to one flashing green light and the blue boost light still showing. when this happens it will only pull about 6500 rpms and the afr reads 15.5-16. happens every time i try to go WO. tried adjusting the blue/green and blue/red as well as solid red with no luck. any ideas on what is going on? bad box? bad tps? bad fuel filter?? guess i should have been running it around sooner than 2 days before the trip :face-icon-small-sad
When you say going west, are you coming from low altitude? Has it ever been set up for low alt? What was it set for? Obviously 10 psi at 8000 ft isn't what to run at 1000 ft. Unless you have c26 racegas
I tuned it here when i first put it on last year. had it running good here. ran it in the big horns with no major issues. was running about 6psi at elevation. didnt know where that would leave me here so i turned it down a little before going out. now only shows about 3-4 psi at the 6500rpms it will pull. I suppose i will fiddle with it tomorrow some, try it at elevation when i get there, and make sure my spare is running good. anyone know more about these kits than me going to be riding togwotee between sunday and thursday??
could someone tell me what the starting numbers in the box are supposed to be? i have 3 sets of numbers written down and dont remember which was which.
also, when running full throttle, is the box supposed to show the number of red lights and the blue boost light or is the one flashing green light and the blue boost light that i am getting normal? i have gotten 2 different answers from people i have talked to
thanks for all the input so far
