W
woodies
Guest
I run at high 12's at idle. About 12.8 Never had an issue. If your gauge is correct, that seams awful lean for idle. Try turning your fuel pressure up at your regulator while at idle before sending in for a reflash.
BB
okay here's an update. after it warmed up and came off hi idle seen hi 12's so may be all is good.took it out for a quik rip but not enough snow to really see much for #'s.how would i turn up fuel pressure?also still stutters a bit if you wfo it,that was gone at higher elevations?maybe a bit more weight on the primary weights?thanks guys new to yammaha so can use all the help!
