Where did you mount your sensors. AEM gauge i have said sensor mounted behind turbo. But we know that it can't be there. Also what sensor is it bosch or Ngk. I have 310 kit and will be running 100% c-12.
help my guage is not working,cycles at start up and then just shows rich.is this a burned out probe?
mines behind turbo?this mean its wrong?mcxnytro!
it can go behind turbo just fine. how far back from the turbo is yours mounted?
couple inches,had it out for a quick run up and down the grass and it never moved off of rich.checked around the wires seem good.guess will have to order new one.will try pulling it is is possible to clean,old owner ran race gas mix and he replaced once allready!going to the mountains in 2 weeks how important is it if not working?
Anybody run this one? www.prologger.com
well i found the problem with my gauge.changed the sensor and same thing rich and never moves,got seriosly pizz off and started to pull the box and guage off to replace.as i'm undoing some tape i find a rubbed spot,spliced and good to go.now my guage is sitting at 13.9 to 14.2 at idle thats pretty lean yes?i have heard that might be the reason nytros are hard to start in cold weather.any thoughts?and also this sled was flashed for 10,000 ft and i'm sitting at 2000 ft and ride 5 to 7000 normally,no head shim.maybe i should sent back for a reflash?
