K
knee deep in it
went for a ditch ride yesterday and the sleds are pretty much ready for the season. I have a couple of little things that i would like to address on my 06 600 IQ
1) when first starting it for the day, you have to hold the throttle in order for it to stay running. It isn't an idle issue, the issue is with the throttle assembly. It seems that the throttle has to engage the safety shut off on the handle bar. If I rest anything on the throttle, it holds it away from the handlebar enough for it to run.
2) again, when sled is started for the first time, the belt seems to remain engaged after you warm it up. If you stop the sled and then restart it, the act of pulling the pull rope will turn the clutch and the sled will creep ahead like the clutch is stuck. After you drive the sled for a few seconds, the clutch operates normally
any help would be appreciated
