I have just gone thru my second seisure and this time I am checking everything.Sent my injectors out to witch hunter had them recleaned and tested static flow is #1 206 cleaned 212 #2 218 cl 219 #3 213 cl 214 #4 212 c 215 pulsed flow cc @ 2500rpm #1 99 cl 104 #2 107 cl 108 #3 106 cl 105.5 #4 104.5 cl 106 cc/min @43.5 psi #1 636 #2 657 #3 642 #4 645 static variance before 5.5% after 3.2% Pulsed variance before 7.5% after 3.7% these are bosch injectors yellow dot #1 is the lower pto side which is the side that keeps going down on my 700 the readings are all low on that injector but with in spec to polaris so I believe. Pistons and cylinder bore here is a surprise. Mag cylinder 3.1888 Mag piston 2000 miles you can still see the coating on the skirt measured 3.179 at the bottom of the skirt = .0098 new piston 3.183 = .0058 pto cylinder from mellioum tech 3.189 piston 3.181 new last year maybe 300 miles= .008 new piston 3.183 =.006 notice the differents in the original pistons both are marked AB compared to the new style piston. Old style had narrow skirts on intake side and are a lot lighter in weight I think last year I weighed one and there is like 8 grams different. I was told by a dealer that they were for a short trac sled and you can no longer git old style pistons this year so I went with new style. old style #2203312 new style #2203512 had to heat piston last year to install piston pin new style slide right in both are built in Italy too much vino on old style.Checked pto seal I pulled a 25 lbs vac and also heated the area around seal no leaks also checked tb manifold at the same time.Pulled my fuel pump and checked lines all good next will be fuel pump pressure. Orded my PCV and will install dyno tech map. Dealer said no way to test ecu but can reflash for $20. Installing new filter in fuel line.So far this is what I am doing to make my sled bullet proof. With enough money and time you can make anything work .I am not sure what the heavier pistons will do to my rpms.I also have it well vented ,clutch is balanced, and the spider is back cut to allow shimming of the sheaves,exhaust valves capped off, coolent hose has shut off installed for tb, carls clutch kit. Pulled my wife sled clutch of to set up clearance and found the spacer and shim were installed backwards so we git to buy a new spacer and I allso back cut the spider .030 now it is at. 010 belt to sheave.So for all of you that are having troubles start doing your own work let adealer go hungry maybe there hands will be come untied.
