R
RMKcowboy
Issue #1- no headlight or gauge lights. Indicator lights in the gauges (brake, etc) work fine. No blown bulbs, no burned or broken wires as far as I can see (if there is a wire problem, it's on the chassis side).
Issue #2- excessive pipe heat to the point of starting to melt the hood. As far as I can tell, there is nothing plugging the pipe or can, but we have had problems in the past on this sled with mice building nests in the can. It has since been replaced and ran fine without problems. It still runs fine but not sure why there is so much heat in the pipe. I'm guessing slight blockage in the can again but not sure.
