98 summit 670 limiter strap
I was wondering how to tighten my limiter strap on my 98 ski doo summit 670 so i could make it lift off the ground easily???
please reply!!
Just have to un-bolt it and move it to the holes you want. If you let the strap out it will lighten the front end. The trade off is in deep powder it will trench more so you might have to adjust the rear torsion springs to balance it out. There are three positions on the rear torsion springs. Just turn the block to adjust on each side.
I was just wondering were the bolt it to loosen it and tighten the strap to make it do a wheelie easier? unless u have to loosen it to make ti lift of the ground??
My old 670 had an adjustment wheel to loosen and tighten. You want to loosen it all the way out. Really easy task.
There are two of them They are wrapped around the torque tube on to and bottom. To adjust you take the nut/bolt off and move it to the next hole.
