900 still not working
Got the sled back from the dealer....seems like discodan/chunky were right...PTO seal seems to be sucking air. Only a half hour labour but I wish I had had a chance to find the tools required to perform the leak down test and found it myself.
I'm going to take it completely apart tonight and see what I can see (expectations are low).
I'll order new seals and I'm debating sending my crank to Adrian Bernard (CV-Tech) here in Quebec to get it checked. I'd rather be sure that I don't have a crank problem since I'm buying all the seals anyway. My only worry is that they tell me there's a problem when there isn't. Everything that I've heard indicates that they are a credible company with integrity so I guess I'll have to give them the benefit of the doubt if I send it to them....I'm currently leaning that way.
outstanding..good to hear man..
make sure your careful removing the engine, careful with wiring, and make sure you use the RIGHT pullers with seperating the stator/flywheel or your buying more parts..
good luck..as you can see..there are some AWESOME guys on this forum..
Sorry for your troubles, but thanks for sharing. Interesting thread.
Good luck.
Best to check it all if you are going that far into it also a good time to check some of the other inaccessable things while it is out like steering system.. thanks for getting back to us with the info!!
