snowmobiler
my brain hurts on how engagement changes.LOL
He is right. Watch the video closely you can see it change the position of the ramp where the ramp pivots.
It won't change the weight but will change the distance the weight of the ramp is away from the clutch. This will change the centripetal forces within the clutch. Therefore, changing engagement. Also it changes the ramp angle so yes, it will change top engine RPM as well.
My question is if 300 engagement equals 300 top engine RPM?
i asked the rotax guys about the new pdrive clutch. I thought you could only Change the engage rpm of the clutch by changing the Primary spring?! The said yes, but on the new clutch, as you can see it in the Video, you Change the whole Position of the ramps out and in and additionally the inclination.
So the wole rpm range moves up and down. If you cange the top rpm up or down, you also Change the engange rpm the same up and down......
Thats what the rotax guys told me......
here is the Video. look at time 3:18 and you can see the movement of the clicker.
https://www.youtube.com/watch?v=c1LoVKaC8Ds
it's not my thinking about the function. i asked the rotax engineers about the function of the new clutch, because i was really impressed of the new design.
But one of them told me, he is also a former snowcross racer here in Austria, that he is not satisfied with the new clickers because of the Change of the whole rpm range especially the Change of the Engagement......
this is only Information directly out of the rotax facility.......
Is the electric start an option on the 850..or standard... ie, can you get an 850 without E-start?
I suspect as the balancing is done by making the tolerance little to no room for variation - making everything weighing the same.Joe,
Coming from your vibration background... I'm sure the new 6-piece 'porkchop' crank is interesting for you.
With the 80mm stroke and no counter balance shaft, and going as light as possible.. wonder if the engine is 'buzzy' at all.
Im curious to see how out of balance the new primary and 850 crank will be ... We will see in the fall if history holds true.
DPG
Why don't you take your cloud of "doom and gloom" and go hang in the Cat section....they need some activity. I seriously can't get over the amount of negative commentary that comes from your keyboard.
In relation to the rotational inertia, we see this engine will be making power around 7800 rpm vs the axys engine spinning around 8400 (depending on mods done to it). That's around 7% difference in rpm. Would the lower rpm make that much difference in the inertia? Or does weight make a bigger difference?
