800R With SLP Performance Kit Commputer Issues?
I have a 07 800r with a SLP Head, pipe, air intake, and reeds. It ran great until this weekend when it started to bog down. It will now only rev up to 7800 RPMs. I know its not jetting because i've ridden in that same spot three times this year and ran great every time. Any Ideas.
Try the clutch bushing. Sounds like what my 07 did. Just replaced bushing on my 09 and gained 500 rpm.
I would pull you primary apart and check the rollers and bushings. I bet something is bad in there.
i have the same problem. started with left boon dock, then right and now any time i load it too much. also if i'm at 5k rpm and give it gas it revs to 7k without increasing speed or power. my kit ripped for the first 600 miles.
I go on here for a little help and get all this crap from buddies. What the heck. It runs great up to 7800. Like it should and then 7800 is max. Still thinking its a computer issue maybe.
i think you need to post more info when does it bog does it ever reach 8000 rpm ?? and if so when? i'm with everybody else clutching!!
have you looked at your secondary? could be sticking but again if you got 500-600 miles on the hp kit then you probably need to rebuild the primary
shoot a stock sled with 500 on a tra usally need some TLC good luck
