Been reading the turbo section for some time and want to build a 800r xp with a 66 aero kit from turbo performance. I have been building and working on engines since i was a child, lawnmower engines to high performance 2 stroke and 4 stroke mx engine and bike builds.
boosted sleds is uncharted territory but not something i am afraid of.
Just looking for wisdom on the build, it will be this summer so i can take my time. Looking to hit high 200s in the hp department
recipe
800r block balanced fresh everything
dual ring mcb or wiseco (leaning towards wiseco from experience, but ive heard alot of bad in the sled world?)
oil injection delete.
cut head for turbo
bmp y pipe
engine tech t-stat
egt and a/f (koso and aem)
weld up stock pipe and wrap it. or is there any insight on what pipe to run
clutch brace
66 aero kit from turbo performance, I havent contacted them yet but will just for some specs and info, for you guys with the 66 how far can you push it before its to far? looking Togo in the neighborhood of 12/15lbs
perks balanced primary, going to dj for clutching needs, oversize rollers etc
fueling, how many of your guys have gone to pipe pressure fuel systems? to me it sounds simple and less parts to deal with then pumps and regs. or is a reg still needed?
compression ratio, I want to push 12/15lbs so i know a cut head and race fuel is required, possibly av gas. (will also talk to big john at shr when the time comes)
closed loop water to air, i want to use the front tunnel cooler to keep boost temps at a reasonable level. Question is will the main tunnel cooler suffice to cool a turbo-ed engine?. long style cooler or barrel and if i cant make something fit i will fab my own out of aluminum and laminova cores. if the engine needs the front cooler, I will put a extra cooler in the tunnel or build one. with the headlight gone i will have the room i need i hope.
for now 2.5 ce 156 track (don't want a boring point and shoot sled)
skid, not sure yet. not sure if i want to do drop and roll for a 3 inch.
And on top of all that I'm toying with big boring it shr860. or bmp 880
alot of custom homemade venting, headlight delete, c3 steering post forward kit, all switches to console lots of goodies
When i build something i go all out
comments, ideas, advice, etc. I read this forum back pages and pages, just love this stuff alot of great info in this place.
cheers
adam
recipe
cut head for turbo
bmp y pipe
engine tech t-stat
clutch brace
cheers
adam
