J
justincredible5
New member
hey guys i bought a blown up 09 dragon 800 this year, i tore the motor down, got the bottom end checked out my a good mechanic in my area he said the rod bearing clearance was iffy so i opted to throw anoth 1000 bucks at it and got a brand new crank, so when that showed up i started assembling, i got the bottom end together with a healthy dose of oil on EVERYTHING that could ever moved, i installed my new wiesco pistons and fix kit with a brand new redone monoblock and i bolted her together, checked the thermostat, filled it full of fluids bled the oil pump, bled the cooling system, and premixed my first tank of fuel, took it to the dealer got it reflashed to the 08 map, brand new fuel, new oil, fired it up let it idle up to temp, shut it down let it cool, fired it up the next day after work, let it warm up, took it for a gentle burn in the field, loaded it up and took it to the hills, got there warmed it up and drove nicely up the trail 40KM into the riding area, always moving it through the rpm band, and not holding it the the bar for more than a second at a time, rode it nicely that day worked flawlessly, rode out, it burned a liter of oil that day and a whole tank of fuel worked really good, filled it up the next day topped it up with oil, then rode the guts out of it that day, worked excellent again, came back down the end of that day, fillled it up the next day but this time with half ethanol fuel and added some oil to the tank and went up the mountain again, warmed it up started headin up the trail, rode it nice, it was at 63 degrees c and about 6300rpm and it started bogging and quit, went to pull it over and i couldnt even pull the rope, pulled the plugs they look excellent, WHAT DID I DO WRONG!!!!????
