440/600?
thought 440 might make a little better power to weight? i'm all about the light weight stuff. if I had my way would have 440 550f and 600ho, but one thing at a time still gotta get 550 finished. taking couple days off. had mtr. in and out about 20 times last night. between notching out frame and mtr ducting. what I thought would be last ducting trim ended up gaffing palm with razor knife, all the way to the hilt. OOOOOUUUUUUUUUCCCCCCCCCCCHHHHHHH !!!!!!!!!!!!
7 stitches and couple days and be back in bizness! might have to give shop keys to a freind to keep me oughta there. these snowhawks are kinda addictive!
Had to notch frame to clear reed cage and cases. going to machine plate and double up frame where notched. it was either this or move whole mtr. forward
and notch frame on both sides in front of cases. I opted to mount mtr. in original posistion.
notch in top of mtr duct is for frame. kind of the same as 503f. will cut out duct holes after mtr is in. (this is where my night ended "slow down, if u get ahead of yourself this is what happens")
thinking about using 600 jaws pipe instead of 503f. 600 pipe matches up better to the stock mxz pipe- inlet, outlet, length and diameter of chamber.
plus stock 503f pipe is smaller than my cr 250?
