I'm trying to put a set of 40mm mikunis from a '01 800 xc onto my '98 700 and I need some help. The 800s have an oil pump with 4 outlets, 2 to the crank and 1 to each carb, the 700 has 3, 2 to the crank and 1 to the fuel pump, can I plug the injectors on the mikuni carbs and run the 700 setup or should I get an 800 pump and run the oil to the carbs? Question #2 the fuel pump for the 800 has 1 outlet to the rack carbs, the 700 has 2 fuel lines, 1 to each carb, should I "T" the 2 fuel lines from the 700 setup into 1 and hook that to the rack mikunis or should I get a fuel pump from an 800 and run the single line? If I run an 800 fuel pump then I would also have to get an 800 oil pump because the 700 oil pump puts the oil into the 700 fuel pump. I think if I run the '01 800 carb boots and the '01 airbox boots the rack carbs will fit, the mikunis are shorter than the kiehens but the mikuni boots should make up the difference. Have also heard that there will be interference between the steering shaft and the r.h. mikuni carb? Also in the intake throat of the mikuni carb there is I believe an air jet, its a 0.8 on the xc and a 0.9 on the rmks, any ideas what I should run for this at 5000' to 6000'? is .9 leaner or richer than .8? Has anyone out there got any info on this swap they can share? or any jetting, general carb setup tips for the mikunis on an ET770 running PSI end dump twins? Sorry about the long winded post but it would be a lot easier if someone has done this or something similar and could help me out. thanks for any help. Jay
