36 inch a arms bind?
J
Jimb
Buddy said don't buy 36 inch a a-arms for a 13-14 rmk pro as the stroke and geometry is too tight and the suspension will not stroke properly.
Bs or true?
On the zbros 36 arms You have to grind your spindles for them to work properly.
Don't know if you have to on the alternative impact arms.
I was meaning if there is no physical rubs does the suspension travel correctly or does the short arms and shocks being stood up more vertically cause the geometry to be screwed up and make the suspension harsh.
As jimb and I talked about through email this is not the case with ours as long as the installation instructions are followed. I am only speeking in behalf of ours.Just want things like that clarified for ALL to see. Thanks!
Dan
