3" track on to regular season Axys. What is needed?
Missed out on snow check and must have a 3" Axys. 163" is preferred but not sure if the correct quick drive gear ratios and drivers are available. Could go with an SKS 155" and find gearing easy enough. Has anyone done this to either ? If so what is needed? What is best sled to start with?
You will need 7 tooth 3" pitch drivers for the aluminum hex shaft. A gear down kit would be ideal but not a must have.
Sent from my SM-G900V using Tapatalk
In Canada so the exchange rate doesn't work so well on anything south of the border. Thanks though Terry. Does avid make center extroverts or do I have to trim rails like the Pro's? Didn't see any other options on thier site. Leaning towards an in season 163 and swapping pulleys & drivers. Hoping there's no other surprises.
