in the front of the tunnel ,with 7 tooth 3" drivers I think it would be fine but the back right where it kicks up it looks like 3" paddles would be right on the side coolers ,with sj brackets and small wheels, if you could get a bit more drop yet it would work with proper clearance or perhaps move the whole pivot forward so the track was more inline with the first section of the tunnel. the drop bracket holds the v of the track about 6" behind the kick up v so that seems to be the clearance problem with the side coolers ,if you had different cooling system it would fit..........any other thoughts or ideas.
