Thanks Laird. I had to file the pins down to make them clear the spider so they weigh 68.3 grams each now. Darrel sent me some longer blocks for my skid also. Hows the snow and thanks again Laird.
Dis some testing today 8700rpm and 15lbs of boost and does not hit the rev limiter at all. This is at 1800ft in saskatcewan but the belt seems to get stuck down in the driven clutch ?
I found there to be a fine line with the shockwave between slipping and gripping. It may not hurt to put a fresh sping in the secondary as they do fatigue over time. Try going in a little on the shockwave and see if it grabs. If you are running a little extra wieght up front it wont hurt to slow the shift a little with a shollower helix angle and keep everything hooking up.
