2204967 vs 2205250
R
realbass
Anybody know?
Can i use 2205250 belt from 14 year to 13 year PRO or can't? Thanks.
the only diff in the belts is the 1 from 14 is said to be stronger and better, u can use 13 belt on a 14 sled and visa versa
So I put a TKI Belt Drive Kit on my 14 and moved my 14 belt to my 13. I also used the 14 bottom pulley as it had an updated part number and seemed to fit tighter on the drive shaft splines. The top pulley is identical to the 13, including part number. The other thing that was different was that the 14 now uses a longer top bolt than the 13.
I did an ask polaris case about this. Both "kits" are new enough to have the 2014 belt but one of them has just the 2 bolts for the 2013's. The one kit has three bolts in it so it can be used for either a 2013 or 2014. One of the kits will supercede to the other P/N. I can't remmember which P/N will supercede though. If you look on the polaris parts diagram the 13's and 14's have different P/N's for the kits, the 2013 P/N will supercede to the 2014 P/N when the 2013 P/N stock is depleted. Hope this helps.
This is incorrect. Part # 2204967 will contain the '13 belt # 3211146. Part # 2205250 will contain the updated, more durable QD belt # 3211167, and an extra bolt.
I just purchased 2204967 last week hoping I was getting the new belt. It has a much newer production code but was still the "46" belt. You DO NOT want the 2204967. In my warranty replacement letter Polaris specified using 2205250 as a replacement. 2205250 contains the "67" belt, that is the one you want.
