Alright who else noticed no factory ice scratchers? WTF
They are available in the "add more options" section
I guess they were to proud to call TKI in Billings. I'll bet lunch that he has (or could make) a ratio that would work.
I noticed on the one slide it says the tunnel is powder coated and not painted. Somedays I would swear Polaris reads these forums and listens.
Also the 3" track weighs 4lbs more then the 2.6" and only 1lb more then the old 2.4. It is the lightest 3" track on the market.
The picture says plus one on top minus one on bottom... wouldn't that be a higher gear ratio? Or are they talking into account the smaller drivers for an overall lower ratio?
You are correct (I pointed this out early on after the January reveal), it is indeed a higher actual ratio, but with the change to the #@!* smaller driver, the realized ratio is slightly lower.
Scott,
If you go to your post #4. It states the opposite.
Edit:
Sorry I posted to late.
Not with the 11mm pitch belt Polaris uses
That's why Tom @ TKI uses a GATES belt for his own belt drive system.
S/C
Right, for $70. Another $70 I shouldn't have to spend, mine came free on my 15 RMK, as did every other 15 purchased.They are available in the "add more options" section
I disagree, I have 2 buddys with a 13 and 15 summit both installed the reversible scratchers. 2 of the scratchers broke off one sled and 1 scratcher broke off the other, now these 2 guys aren't the brightest friends I have, but, still concerning that their $90 scratchers broke and mine have worked fine all season.factory ones suck. the doo t3 reversible ones are going on my next sled which will be an SKS and they should work with the extra wheels.
